1997 F-250 Driver Side Door Not Working
At first it was just hard to open with the original door handle. After a little bit I pulled on it a bit harder and it snapped right off. So, I went out and got a new handle from O'Reillys. Now it is just not working all together. The outside door handle works. I used WD-40 on the cable and latch and still nothing. Any help is much appreciated, thanks!
Sometimes you can get away with putting a fender washer behind it to support it.But welding the door is a much better repair.Don't want to get locked in when you need to get out.
Good luck
GavinL
11-21-2018 12:51 PM
*2fords*
07-02-2016 12:51 PM
Jacksfirstdiesel
20
05-19-2010 12:01 AM
