Go Back   Ford Truck Enthusiasts Forums > Ford Truck Enthusiasts Site Navigation > User Gallery & Picture Display Help
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-09-2013, 06:14 PM
Yaga1973's Avatar
Yaga1973 Yaga1973 is offline
1996 Ford F-150
My Garage
Yaga1973 is starting off with a positive reputation.
Linked Pictures Not Working
Hello,
I've noticed that all of the photos I've linked to in my posts from Flickr aren't showing up. Only the html code or URL is showing up. Here is an example of a URL:
IMG]http://www.flickr.com/photos/yagablue/8363200090/[/IMG]
Here is the example of HTML code:
IMG]http://www.ford-trucks.com/forums/<a href=[/IMG]
In each case, this is the same picture. Other pictures from this album are also not loading. So, here are pictures from another album to see if that is the problem:
Posting with a URL:
IMG]http://www.flickr.com/photos/yagablue/6769220057/[/IMG]
Posting with HTML code:
Does anyone have any idea what is going on with FTE and Flickr or my albums on Flickr? I haven't changed any settings on Flickr or on FTE so I'm at a loss. I just know my images don't appear yet images from others do appear. Perhaps theirs are hosted on FTE. I normally use Chrome for my browser but for this post I used IE to see if that was the issue. Both of my browsers are up to date. Also, I've noticed my pictures don't show on my android, my home PC, or my work PC.
If anyone has possible solution to my problem, I'm all ears.
Thank you,
Aaron
__________________
1996 F-150 4.9 5-speed 2WD Short Bed
Planned modifications: 4WD Conversion, some engine mods that are EFI friendly
1983 F-150 Longbed Dual Tank, 300 I6, 0.040, RV Cam (Stepfather currently owns this)
Planned modifications: Offy DP Intake, 600 CFM Edelbrock Carb, EFI Exhaust, Walker Y Pipe.
Last edited by glruff; 01-10-2013 at 06:21 AM. Reason: To show codes typed by user
  #2 (permalink)
Old 01-10-2013, 06:12 AM
glruff's Avatar
glruff glruff is offline
2005 Ford Ranger
glruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputation
You need to copy and paste the ".jpg" code and not just the link to the page where the picture can be found.
Click the image to open in full size.
RH Front Angle by Yagablue, on Flickr
In Flickr, click on SHARE, then GRAB the HTML.BBCODE, then check the BBCODE. Copy and page the code that shows in the box.
__________________
George, FTE Chapters Moderator - FTE GUIDELINES
05 F250 6.0 FX4, Innovative Diesel Tunes/10 Expedition EL LTD/12 Explorer LTD EB/13 Platinum F150 EB
  #3 (permalink)
Old 01-10-2013, 06:18 AM
glruff's Avatar
2005 Ford Ranger
Here is a LINK to the page for one of your pictures:
RH Front Angle | Flickr - Photo Sharing!
You are apparently adding the wrong codes when posting a link.
__________________
  #4 (permalink)
Old 01-10-2013, 07:21 AM
Yaga1973's Avatar
1996 Ford F-150
My Garage
Very good, I'll try the BBCODE since I've been using the HTML. I've also been grabbing everything in the Share box using URL or HTML. When I get to a comp I'll try a couple tests here. What's funny is that I've used the HTML before and it worked. It only recently stopped showing pictures in my post.
  #5 (permalink)
Old 01-10-2013, 07:35 AM
Yaga1973's Avatar
1996 Ford F-150
My Garage
Here is the first test with BBCODE:
Also, I've noticed that if I use the "Insert Image" box, the [url] shows up on top and bottom of my photo and the caption trails the photo instead of showing beneath it.
Here is a test with HTML without using "Insert Image":
<a href="http://www.flickr.com/photos/yagablue/6769220057/" title="RH Front Angle by Yagablue, on Flickr"><img src="http://farm8.staticflickr.com/7166/6769220057_fbc42f9f56_b.jpg" width="1024" height="768" alt="RH Front Angle"></a>
Okay, so that didn't work. Here is HTML using the "Insert Link":
Okay, that just showed the hyperlink, which is accurate. Here is a final test of "Insert Image" with HTML:
[IMG]<a href="http://www.flickr.com/photos/yagablue/6769220057/" title="RH Front Angle by Yagablue, on Flickr"><img src="http://farm8.staticflickr.com/7166/6769220057_fbc42f9f56_b.jpg" width="1024" height="768" alt="RH Front Angle"></a>[/IMG]
Didn't work. And just to round things off, here is BBCODE again without using "Insert Image":
So, it seems that I've got it figured out. How odd that using "Image Insert" and HTML worked a little over a month ago and now it doesn't. I'll have to have an admin help me make changes on one of my posts that is older than 30 days so the images will display again.
Thank you for your help, glruff!
__________________
  #6 (permalink)
Old 01-10-2013, 09:55 AM
glruff's Avatar
2005 Ford Ranger
I think admins turned off HTML code a week or so ago.
__________________
  #7 (permalink)
Old 01-10-2013, 10:23 AM
Yaga1973's Avatar
1996 Ford F-150
My Garage
Well that would explain why my pictures went away! LOL! Do I need to contact the moderator of the forum I posted in to restore my photographs? There is only one closed for editing post that I need to do this with.
__________________
  #8 (permalink)
Old 01-10-2013, 03:12 PM
glruff's Avatar
2005 Ford Ranger
Quote:
Yes or send me a link and I will see if I can help
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
