94 F150 Power Steering Issue Help Please!
Let me set the tone quickly, 94 F150 4X4 351 Back in 2/2011 I changed out the power steering gear box, flushed with regular power steering fluid. Everything seemed fine for almost a year now. About a week ago I developed a issue where I don't have much power steering, but just when turning to the right, and mostly while sitting still. One would think the power pump was getting bad, so I swapped that out this weekend with a remaned unit, and flushed it out again with just regular power steering fluid. The issue is still there, it didn't change one bit. I was thinking a hose, but that don't make much sense as I have good power to the left. If the truck is moving at all, I have power both ways. The issues is just while sitting still. I thought about a tight ball joint, or another suspension item, but they move great if the truck is moving. Is it possible the gear box is bad again? I would try a hose, but can't seem to locate one, as mine has the standard fittings on it, and they only have a metric hose, pretty much everywhere I checked. Should I try changing the fluid to a ATF type fluid? Appreciate the help. Thanks
Make sure your front end is greased and not binding. Tie rods, and ball joints as you mentioned. Make sure you don't have an axle u-joint that's starting to seize. Most of these items would make it harder to turn the wheel while sitting still, but easier once it has the momentum of the tires spinning to help.
I had a similar problem in my former 93, which advanced to it being hard to turn to the right all the time, even when moving. I can't remember what exactly was wrong with the steering box, but that ended up being the problem. If yours is under warranty, it's probably not a bad idea to think about replacing it.
While I'm not sure what thread the stock hoses should be, unless you've installed a Saginaw (upgraded) pump, the stock hoses from any parts source should fit.
Thanks Bob, I have checked the suspension parts, and all seems fine there. The problem with the pump and is, and this is from what I have been told, is where the truck was probably built, determined what pump it got. It looks like most trucks will have the metric fitting. Every parts house I checked had a metric pump and hose in stock. There was a week wait to get a standard fitting pump, but no listing at all for a standard fitting hose at all. I know I could swap the fitting out, but when I took the core back it had to have a fitting in it, so I had to sent back the metric fitting. If I had know I was going to try a hose next, I would have just use the metric fitting, and got a new hose then.
88n94- I think I will change out the fluid this weekend, and see if that helps. But I really believe its the gear box again. Thanks for your all suggestions.
LOL! I couldn't believe it either, makes no sense what so ever. I didn't check with the dealer, but I would think it has been discontinued. I guess I could have a new hose made with my old fittings, if need be. But I'm really leaning toward a gear box. I will try the fluid change this weekend, but I'm going to have them get another box, if they don't already have one in stock. I saw on this site about a group buy on Red Head Steering boxes, but I have never saw a price on them, does anyone know about them? Thanks, Jeff
I'd love to get in on a group buy for a Red Head. My truck is going to need a box soon, and from what I've read, nobody has ever had any problems with them.
I contacted them a couple of years ago, non-group buy pricing was around $300 by the time you get done with shipping, and sending your core back to them.
Well Bob, I ordered one today. For my truck, $256 for the box, $75 core and since I returned my one off the truck as defective, and they got rid of my core, I did get my core charge back, and $34 shipping. Grand total of $365 to my door. The only thing I didn't like is it only has a 1 year, unlimited mileage warranty. But after talking to Bruce, I decided to go with one. I wish some of the guys who got a Redhead in the group would chime in and let us know how they are holding up after having them for some time now. Also I looked around today for Ford Type F fluid, and didn't find any. They tell me it's been replaced with DexronIII/M???? Is this the right fluid to replace Ford Type F?
I thought so too Bob, and with only a 1 year warranty I had to think about it. But after talking with Bruce, he said if I had any problems, and it was their fault, he would work with me on it. So I decided to go with one. Hope to have it on the truck by next weekend. I'll let you know how it goes.
Fdude Thanks for that info, looks like I'll try to get some F type. You know these guys at the parts houses, they will tell you this replaced that just to make a sale. It's hard to find good help!
