Need Ignition help on 78 f100
I got a 78 F100 a 514 in it and just got finished installing a MSD 6A ignition box, Blaster SS coil, and Pro Billet distributor now i cant get it to start it ran with the old distributor and stock ignition but I needed better fire. Its getting plenty of fire and fuel and has been put back to TDC and firing order is correct Ive triple check everything I pulled the number 1 plug out to see if it was getting fire and went to turn it over and the truck fired up with the number 1 plug out of the cylinder. I have no idea what is going on and need some help on this problem. Thanks
Yea that's what I'm saying, I had the #1 plug out of the engine with the plug wire attached to the #1 plug to check the spark, then turned the engine over by touching the solenoid with a screw driver and the ignition on, when I did that the engine started up. I quickly shut the engine off and put the #1 plug back in the engine and tried to start the engine and it would not fire up. That's as simple and plain as I can put it anybody know what might be going on with that?
There are only two explanations for what you're seeing:
1) You have some sort of odd cross-firing issue, having to do with plug gap, broken coil tower, or bad wires - such that the added path to ground somehow breaks it. I have never heard of this happening.
2) Something else is going on that you're not aware of or not making clear in your description of the problem.
You need a wiring diagram , a multimeter or test light . You should have power supply to ignition from switch while in run and start . I think you are loosing it in start . With a wiring diag . you can trace it down .
You jumped the solenoid , and it started . It won't start with the key . Is that correct ? Sounds like you are loosing power to ignition while in start position . Try jumping solenoid with plug in and ignition on . If it starts , you are dropping power while key is in start .
