Turbo ?? 460?? Could it work?
Yes, it will work, but it's a very involved process. It sounds like you need to do a lot of reading on turbo gasoline engines in general before jumping into a 460 build. There is very little support out there for a turbo 460 NOT designed for drag racing.
You might want to look into finding yourself a used Vortech kit for the 460 if you want to play with forced induction. Its a great kit to get you started with FI since it's a fairly straight forward install (if you get all the parts), but they're getting rare and they are bought up quick when they're for sale.
Thanks for flaming me tho, i appreciate *********s
Bob Gervais, I was gonna throw some Rep your way, but apparently I've gotta spread some more around elsewhere first.
firerescue9, believe him, you better sit this one out. I don't care if you know everything about every turbo ever made, it was quite apparent that you didn't do much research before trying to put a Dana 60 rear underneath your truck while the Sterling is a much better, easier, and cheaper option. Now that's stupid. So leave this guy alone, will ya?
Leave the guy alone.... wasnt he the one who made the comment. And i did research. Its not like people havent done a rear d60 swap befor.. Not everyone has the funds/ability to find a 10.25. I couldnt for a long time hence me asking about the d60. I still dont understand why i get so much sh.i.t for asking.
Thanks everyone
So first things first what is a good reliable source to read up and learn about turbos? Second I plan on goin to a junkyard and ripping one off a 7.3 and if need be maybe rebuilding it !?? Any problem in that? I m not looking to go fast just little more pulling power and maybe some better gas mileage, and of course the nice little whistle. I know it's a long process and involves a lot I am capable I just need some direction and knowledge from people who done this.
If you're serious about building a turbo motor, you should read Maximum Boost by Corky Bell. Eventually every site you go to on beginner's turbo builds, somebody will point you to that book.
One of the members here, Lead Head, has a post where he dropped a 7.3 Powerstroke van turbo on his 460. The thread is found here: https://www.ford-trucks.com/forums/1...-0-85-vid.html
There's no denying that power will increase, but the 7.3 turbo isn't sized perfectly for the motor either, but based on Lead Head's videos on Youtube, it seems to do very well for the total investment in the project. As far as fuel mileage goes, I doubt that you'll see any gains in fuel economy. Best case scenario, you'll keep your current fuel mileage while greatly increase the power output. If you read up on forced induction, the brake specific fuel consumption (BSFC) is higher on turbo and supercharged motors which points towards lower fuel economy in general.
Yup, we just kind of dove into that project. The only goals at the time were find the biggest turbo possible locally...and that's about it. We did plenty of research before hand, but there was a lot we learned during the install - and unfortunately there is a lot more we learned after we got everything all installed.
So ~2 Years after it was finished, it really needs to all come apart again and be redone. A properly sized turbo, charge-air piping, revised oiling system, fuel pump changes, engine rebuild and more.
You're not really going to gain any fuel economy from a turbo, my buddy gained ~1MPG, but not from the turbo. More than likely from the mass-air and tuning changes. It'll never pay for itself.
