Remote Start with Snow Covered Windshield
Had a lot of snow in the North East last week. Tried to use the remote start three times without any luck. Cleaned off the windshield and it worked. At best the remote is a weak system with very little range. Any suggestions on how to use it or make it work better?
remote
I have the remote start and I don't think the amount of snow has anything to do with it. I live in Northern Ontario, Canada, and we get very cold temps and more snow than usual and snow doesn't affect it.
However, the OEM remote on this truck is not nearly as good as the aftermarket remote I had on my previous Chev. Not only for distance but for actually starting the truck. I have had several times when I thought I would have remote started the Ford truck only go get outside and find out it never started. I would really like to have an indicator on the remote FOB that shows the engine has started. My aftermarket would start the truck no matter how much concrete I had to go through and at a much greater distance. I could be in the arena watching a hockey game and a fair distance away and the aftermarket started my truck every time. My aftermarket was about $400 plus so not a cheap one. The OEM is a cheaper unit by Ford and that is why it starts sometimes and other times doesn't start the vehicle.
My next truck won't have the factory remote start and I will just add an aftermarket unit. My aftermarket remote start also had a cold start option set-up. Meaning you could set up the vehicle to start through the night at confirmed intervals to keep the engine warm. (I guess in case you didn't have, or couldn't connect your block heater??) The aftermarket was just superior by far to the OEM unit.
My 05 had an aftermarket remote start. I liked it because it would run for 25 minutes at a time.
Also the cold start option was nice. If it was -35 and nowhere to plug it in that night, it would start every 4 hours and run for 15 minutes. Never had to worry about it not starting.
That being said, my 2011 starts at -35c with no issues when not plugged in.
Gordon
I have the Ford remote start system on my truck and I found that I couldn't be in my bedroom and start the truck but other than that it worked fine. But...then thieves stole my wheels and some other items from my truck while it was parked in frot of my house so I purchased a Viper Alarm with a remote start included. The alarm has a shock sensor and I added 4 mercury switches to it as well, the Viper remote start is far superior to the Ford one in that I can remote start it from blocks away and the 2 way key fob lights up when it starts and gives warning beeps when it is about to shut off and when it does auto shutoff the lights flash and it has a distinctive shut off beep too. I really like it a lot.
Have a great weekend,
Randy
Randy
ddlv
01-20-2009 08:48 PM
