distributor-points vs electronic
Old 06-24-2014, 08:52 PM
raven3's Avatar
raven3
raven3 is offline
Will a 300-6 ,65-73 distributor with points fit a 1974-1986 300-6 that is OEM, Duraspark II ignition?
Old 06-24-2014, 10:27 PM
6978sghfbjklgdfsjhkl's Avatar
6978sghfbjklgdfsjhkl is offline
yes, if your are prepared to wire it up..it will drop right in.
Old 06-24-2014, 10:51 PM
raven3's Avatar
raven3
raven3 is offline
Less wiring with points than Duraspark.
Old 06-25-2014, 01:02 AM
I know..the point would be for you to be comfortable doing it. (I keep a points kit close for mine).
Old 06-25-2014, 09:40 AM
raven3's Avatar
raven3
raven3 is offline
With lower rpm of the 300-6, seems like the points would work just fine and more reliable than the Duraspark electronic module setp.
greentruck72
02-23-2015 08:10 AM
73FordF100
15
01-25-2012 01:44 PM
Fomoko1
22
02-14-2009 11:35 PM
LARIAT 85
11-16-2006 06:30 AM
70_f100
08-20-2005 12:48 AM
Quick Reply: distributor-points vs electronic
