Small switch under dash?
Old 12-27-2012, 02:40 PM
FV82's Avatar
FV82
FV82 is offline
I have a switch under the dash that Im not quite sure what it does. I have an 07 XLT supercrew. Has the factory alarm I imagine. My brother has the same year, but no switch. Doesn't seem to do anything, tried to trace wires, the seem to join up with some other wires under neath the steering console area.
Here'a a pic:
http://dl.dropbox.com/u/8102696/photo-1.JPG
Old 12-31-2012, 07:48 AM
60DRB's Avatar
60DRB
60DRB is offline
Does not look OEM.
Old 12-31-2012, 08:50 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
I'm with 60DRB...it's NOT an OEM switch. It's likely an aftermarket alarm switch, or it could be tied to auxiliary lights.
Old 12-31-2012, 05:09 PM
hoytshooter119's Avatar
hoytshooter119
hoytshooter119 is offline
I may be wrong on what it actually is, but I call it a valet switch. If for some reason you set your alarm off by accident you will have to push this to reset it as well as get it to stop the alarm before you can start the vehicle. I once set mine off by showing off my remote start (forgot the ECM had a code which will not let truck start by remote) and pressing the buttons to many times, and causing the alarm to go off. Very embarrassing moment by the way.
Old 01-04-2013, 11:28 PM
stangdude's Avatar
stangdude
stangdude is offline
I'm with you, looks like a valet switch to me. Easiest way to check is roll the windows down, lock the truck (to set the alarm) reach in and open the door from the inside (to set the alarm off) then hit the button to see if it kills the alarm.
Old 01-04-2013, 11:38 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
I may be wrong but believe it is part of a viper system? I have seen them also. A small size toggle switch just hanging there.
FV82
Electrical Systems/Wiring
12-27-2012 04:05 PM
Ryan87lx
1999 to 2016 Super Duty
04-12-2008 08:49 PM
bmconway76110
1997-2006 Expedition & Navigator
12-26-2006 10:28 AM
Thudpucker
1997 - 2003 F150
08-29-2005 04:21 PM
rellik74
1983 - 2012 Ranger & B-Series
02-08-2002 10:34 PM
Quick Reply: Small switch under dash?
