1960 F100 Original Style Bench Seat Covers
Old 07-07-2010, 09:15 AM
montego69's Avatar
montego69
montego69 is offline
Hi all,
I searched the forum and looked at a bunch of the normal restoration supply houses and could not find anything that mentions stock style seat covers. My F100's stock bench is pretty torn up so I'm going to restore it. The stock seat is red vinyl with two black, cloth/woven panels on the seat back. In between the two panels there is an embossed Ford emblem with the gear and lightning bolt. Anyone know of a company that sells this style as new?
Thanks all,
Nick in WI
Old 07-07-2010, 09:25 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
Originally Posted by montego69
Hi all,
Thanks all,
Nick in WI
talk to MidFifty (midfifty.com), 800-252-1956
they should be able to give you guidance..
they have a catalog of replacements as well..
Sam
Old 07-08-2010, 08:33 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
Mid-Fifty only does 53-56 pickups...
Try Macs in Buffalo. NY
Old 07-08-2010, 09:38 PM
transam525's Avatar
transam525
transam525 is offline
You might be able to find NOS material through these guys:
Home of Original Auto Interiors
Old 07-09-2010, 06:51 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
smsautofabrics.com, located in Canby Oregon.
I know they have original and correct 1961/66 material and can emboss the gear and lightning bolt onto the backrest, but you'll have to contact them for prior years.
I have parts catalog pics of the original FoMoCo swatches for the seat upholstery...in color. For 1960, the trim code was T03 for "Red and Light Grey" Vinyl.
Old 07-09-2010, 07:33 AM
montego69's Avatar
montego69
1960 Interior
Thanks everyone! I appreciate it.
Jesse at Midfifty's gave me a number for a company called Seatz located in CA. I'm also getting samples from SMS (who I bought the cloth and vinyl materials for my 69 Montego's interior from.)
I also learned my bench seat is not original to the truck. The experts say the embossing on it points to 64-65. Under the seat, hog-ringed to a spring is a metal tag with "Reynolds" stamped on it along with a part number beginning with a C4.
After I get my sample materials, I just have to decide if I stay with stock 1960 or go with the embossed style.
Nick
Old 07-09-2010, 01:13 PM
NumberDummy
My bench seat is not original to the truck, I found a tag on the seat with a number beginning with C4.
No cloth was used on 1961/66 F Series seats. Either all vinyl-Standard Cabs, or vinyl and woven plastic-Custom Cabs.
According to the colored swatches, there is one BODY code that matches this criteria for 1964.
BODY code E81 (Custom Cab): Red crush vinyl & red check stripe woven plastic.
There are two variations: Trim code 5: Red crush vinyl with two black stripes. Both stripes are the same width.
Trim code 13: Red crush vinyl with two black stripes. One black stripe is wider than the other.
Old 07-09-2010, 01:33 PM
montego69's Avatar
montego69
This is what the seat looks like now.
ND- you're right that the black area really isn't a cloth insert. It's like woven plastic.
So my seat probably came from a custom cab?
If I got the body code from my 1960, could you tell me what my soft trim was originally?
Nick
Old 07-09-2010, 01:49 PM
NumberDummy
Nick
I can decode 1960, I believe the Warranty Plate will have TRIM marked on it.
The upholstery pattern on this 1964 seat has been modified from its original form.
There were no divided panels styled like this on the backrests of 1961/66 bench seats.
These backrests have about one foot of vinyl above, two feet of woven plastic (Custom Cabs) below, divided by a straight line.
Appears that someone added the inserts which do not match the swatches, divided them with red vinyl. This embossed emblem is not the same as was used 1965/66.
IMO, this was originally a Standard Cab seat, based on the location of the embossing. Whoever reupholstered it was able to save the upper section of the vinyl that contained the embossing.
Old 07-11-2010, 11:04 AM
montego69's Avatar
montego69
warranty plate location?
ND,
There is only the pop-rivited vin plate on my glove box door. Color is J. It looks like there was something else stuck to the door which has been torn out. There is no other plates or stickers stuck anywhere else. That warranty plate is probably long gone unfortunately.
There probably wasn't more than 1 interior color that went with exterior color J, right?
Thanks,
Nick
Old 07-12-2010, 01:51 AM
NumberDummy
ND,
Wrong, there are 4 possible interior choices, one or all of them could have been used with a red (or white or black) exterior.
The Rating aka Warranty Plate is pop riveted to the inside of the glovebox door. Has the VIN, codes for the W.B. (wheelbase), COLOR, MODEL, DATE, TRANS, AXLE and etc on it.
There was once a decal on the inside of the glovebox door that had tire info on it, but that's prolly missing by now.
COLOR code J = Monte Carlo Red.
Old 07-12-2010, 07:25 AM
montego69's Avatar
montego69
4 possible choices...
ND,
That's good to know regarding the fact that any one of the four colors could have been used. Guess I can make it my choice now since no documentation or proof exists as to what the truck had originally.
I'm spraying the original red back on inside and out.
Thanks,
Nick
Old 12-24-2012, 11:19 AM
69jwatson's Avatar
69jwatson
69jwatson is offline
i know this is an old thread but was wondering if you knew where I could see a picture of my 69 f100 ranger seat upholstery? The trim code is N and the scheme is Dark red Corinthian vinyl and red granada pattern vinyl.
Old 12-24-2012, 12:54 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
Nick, you might have better luck getting the photos you are wanting, by starting a new thread in the 67-72 Forum. Good luck, Steve.
Old 12-24-2012, 08:16 PM
spurredon's Avatar
spurredon
spurredon is offline
It will take you awhile but if you click thru the galleries of the '69 trucks, you may just find what you are looking for!
HEAVY100
13
10-01-2011 09:24 PM
JER1517
05-04-2010 12:14 AM
gplus
05-08-2008 02:54 PM
WALFORD'S 56
07-29-2007 09:40 PM
Vien
02-10-2004 11:58 AM
Quick Reply: 1960 F100 Original Style Bench Seat Covers
