Flywheel Noise?
Flywheel Noise?
I have a "52 239 FH and have gone through the engine replacing all bearings, installed adjustable lifters, etc. all was well. Developed a slight knock. Opened it up, re-tightened all rods, mains, adj valves, pulled pistons, replaced a questionable wrist pin, pulled all valve guides, etc, etc. Still have "knock". I was told that it may be a warped flywheel???
I have not gone into this area yet because the clutch and tranny are working fine.
Before I chase this dog, is it a valid pursuit?
Any thoughts?
Any thoughts?
I have checked the top and bottom for signs of the cause of this rather loud noise. I am now grasping at straws for a solution.
The good news out of all of this is that my 29 year old son, who loves "wrenching" has learned a lot about the ol' flathead while helping his Dad chase this gremlin.
I researched the flywheel idea and got very sketchy "maybe" info. Guess I am just wearing down trying to figure it out.
Thanks for your input.
Did you run/drive the engine before the rebuild? Was it making that noise? Does it make this knocking under load, idling, or all the time equally? You can eliminate bearings and rotating assembly if it is not different under load.
I put a new clutch PP in mine and it did not quite clear the BH bosses for the trans bolts. It was a pretty hard hit, sounded terrible, but a lesser hit might sound like a knock. Any chance you can record the sound in a video?
The rebuild was done a couple of years ago, very few miles on it since then (less than 100).
The noise seems to be related to crank speed, not lifters or valves. It is the same all the time, just increases with engine speed.
I have not touched the flywheel, clutch as the rebuild, due to limited shop space was done while the block was still in the truck.
I will use a stethescope "again" to try and isolate the noise.
Thanks
Thanks
