No, it is a Kelsey-Hayes I bought years ago from Hitch Headquarters in Hampton VA. Bought it not long after I bought Darth. He had an electronic one that was horrible, it would surge and pulse when you applied the brakes.
Our van has the same branded controller, but a different model. I highly doubt I'll ever even use the one in the truck. But, it's there.
Took the truck for a good drive today to a couple stores and back home on the freeway. Fan shroud works very good. Cools it right down and keeps it around 190 when idling after it runs for a minute. I floored it a couple times on the freeway and the holy crap o meter went high. That mechanical fan had a big drag on that engine before. No cooling problems at high speeds either. Runs at 190-195 on the freeway with the fan off. However, it was pinging at WOT. I have a brown secondary spring in, I'll go down to the next fastest opening spring rate. Should fix that. I know it's not the timing, it's 11* BTDC and full in by 3000 RPM.
