PTO trans help
PTO trans help
i need some PTO trans help. the f550 i bought has a pto trans how what do i need to use it. all it has in the cover on the trans. do i need an adapter or will the item i want to run bolt up? i think i need the adapter to get it out of the trans to where i can hook up a pump. i have a AIC coming to run the pto just need to find how to hook it up.
I'm not keeping the truck my dad traded me his f250 for it and he would like to know how to use it.
if any needs a good 250......
thanks Matt
thanks Matt
The pump bolts directly to the trans. We use Muncie pumps that are clutch activated. This means the pump gear is constantly meshed with the PTO gear in the transmission. Then transmission fluid pressure is used to activate the clutch thus driving the hydraulic pump.
You do not need the AIC. It is nice but not necessary unless you really need to vary idle speed or remote start and stop feature. The factory high idle circuit works for most applications.
I did some research a while back and about the only thing I could find was the Muncie pumps (thanks to an old post by shake and bake IIRC). The Muncie pump will then operate a variety of implements, such as anything hydraulic (lift bed, snow plow, etc...) and there are implements such as air compressors and generators that can run off of it as well.
I think Riffraff has an air compressor on their website that bolts in place of the 2nd alternator. That would be a much better option than using the PTO since the compressor would be engine driven. The PTO can cause the transmission to get hot sometimes so we've sorta gotten away from transmission driven units on the smaller class 4 or 5 trucks.
I'll attach some pdf documents for the Muncie pumps so you can see what is involved.
The following users liked this post:
Thanks for posting this. That will go to the top of my wish list if it really will bolt right up in place of 2nd Alt. I'll have to look into it more.
I don't even know where the second alternator goes. I don't have the wrap around coolant hose, so I'm saying no, but I'll go look...
But here's a thread to read through about adding the second alternator. If the compressor is going in instead, Just need the bracket, bolts, and new belt. All the wiring is not dependent on the PCM.
https://www.ford-trucks.com/forums/2...uccessful.html
Here is a pic. This is a hydraulic pump that is attached to the clutch drive gear set. It is basically what you are describing, an adapter with a pump on the back.
thanks
