Fog lights and High beams together?
It's called "Bambi-Vision" or "Better Bambi-Vision" .... Google it.
https://www.ford-trucks.com/forums/6...ber-relay.html
There is a video here I see, though I've never looked at it:
I did it on my '07, I use the fogs some for filling in the ditches with high beams on.
You can run fogs with high or lows .... what get's the tickets is not diomming the highs to low .... or in the case of 4 headlight systems, having 6 lights for general illumination on at once.
They just factory wire them with low beams as the intent is to add light in fog without blinding the driver with reflected light. Fogs down low under fog's thicker layers.
