3.5 violent shudder and limp mode
So I just bought a used 2013 F-150 EB with 59k on the ODO. Twice in two days while towing it produced a violent shudder and loss of power. When it happened the second time it was followed by the truck going into limp mode.
Of note, the engine was flawless when not towing.
I live in the northwest and everything I read led me to believe it was likely the intercooler and possibly the cat as a byproduct of the unburnt fuel being ejected into the exhaust.
Today the dealer called and said the problem was the high pressure fuel pump. I can't seem to find any like incidents to mine (fuel pump causing a violent shudder while towing).
Any thoughts?
Any thoughts?
Welcome!!
This is the first fuel pump that I've read of. Just for giggles, do you know if your plugs have been changed yet? If not, get them changed to head off another casualty while towing. The plugs on these ecoboost trucks typically run about 50K-60K miles then you could possibly experience a misfire event that would lead you to think that your intercooler is loaded with moisture.
No cost listed on the work order.
Changed the plugs today and they looked relatively okay. Electrodes worn to a gap of about .038. Even wear on all plugs and no carbon tracking.
Drilled a 1/16" hole in the CAC which drained and blew quite a bit of oil, but no water. It was showering and in the low 50's here today (and all week), so the conditions were right on the money.
Your new plugs should be gapped to .030 and changed every 30k miles to be safe. Your weep hole was an excellent choice as well. The problems you experienced were directly attributable to the spark plugs and condensate buildup. Now that you have addressed this, keep an ear open for the cold start rattle which indicates your cam phasers are failing.
No timing chain issue so far.
You're assuming that was the problem to begin with and not what the dealer fixed. I live in the Northwest and I know multiple EB owners, including some that have modified their truck. No one has any issues to report. Furthermore, I've yet to see anyone with credible evidence or reputation state 30,000 mile intervals are needed on a non-modified EB.
Mystic_Cobra
6.7L Power Stroke Diesel
83
12-22-2017 07:19 AM
