Need Year ID Help
It's a 1980-1986... Head on over to the Bullnose forum and they can help you get it narrowed right down to the year and any tech help you need.
https://www.ford-trucks.com/forums/forum37/
Received 3,108 Likes
on
The grille w/the blue oval emblem is 1982/86, but Ford replaced the 1980/81 grille with this one in 1982 for use as a "service part replacement."
So, because of this, you cannot go by the grille to ID what year the truck is. If it is an F100, it could be a 1980 thru 1983.
1980 VIN composed of 11 digits, 1981/86 VIN composed of 17 digits.
Certification Label glued to the left door face below the latch. Has the production date printed on the upper left corner, the VIN and etc. codes printed on it.
VIN plate with the VIN stamped on it located on the left corner of the dash, visible thru the windshield.
Compare the VIN on the tag to the VIN on the Certification Label to see if they match.
So without the Vin# or manufactured date it's just a guess.
elektrafried
23
12-27-2006 08:06 PM
Tim Halliday
General Automotive Discussion
09-25-2004 03:11 PM
