I have 68 Pickup that i want to change the motor in it so I can restore it back to the original how can I tell what the original motor was
I know this might sound like a strange question.. Why? I mean, there is no such thing in this vehicle series as "numbers matching" The only reason I would even consider going back to original is if the truck is a SUPREME example of a truck. Otherwise, I'd look for the best performance and ease of maintenance given your budget and skill level.
The closest you'll get to numbers matching is being period correct. With very few exceptions, like the K-Code 65 Mustangs and its other K-code brethren, no VINs were stamped on engine blocks and heads. Being period correct is equipping it with date-coded castings and parts that would have been installed on your rig. Among the diehard Mustang crowd, that means within 90 days of the build date.
Originally Posted by willowbilly3
Post up the numbers from the data plate and someone will tell what it was originally.
2x... the 4th character of the VIN will indicate its original engine size.
If the original stamped metal tag is near the distributor it will identify the engine and I'd think that would be a necessity if you wanted "numbers matching"
