1989 f-150 5.0
1989 f-150 5.0
Unless your modified for ALOT more airflow thru the engine then stick with the stock-flow injectors. My engine still utilizes the stock 19# units and is all I need. An adjustable fuel pressure regulator will give you some flexability in increasing potential fuel flow but unless you plan on modifying heavily then stock pressure setting is all you need. With an adjustable FPR you can probably increase potential fuel delivery by about 15%. With an essentially stock engine turning up the pressure or swapping in larger injectors will only cause problems.
Randy
Randy
1989 f-150 5.0
Agreed.
The injectors are just part of the solution to bigger power.
Everything has to stay in proportion. If you increase the fuel flowing in, you have to increase the air to match. To do that you may need a fatter cam, head work, intake porting, exhaust upgrades, mass air...
Not to mention the fuel pump, lines and filter, AFPR, fuel rails...
It's like a never-ending saga.
Unless you plan to put some more money into the whole motor, just stick to the stock injectors.
1989 f-150 5.0
I would take a look at the Diablo Delta chip and buy it right here at FTE. Money back guarantee if the chip doesn't meet your expectations.
Any time you can reduce the temperature of the air charge then you'll pick up some ponies- and economy as well too. Take a look at http://www.performanceunlimited.com/projectmpg
Randy
Randy
Renneberg
08-03-2014 10:47 AM
ferguson777
07-07-2004 05:56 PM
