Ugly Betty: Frame-Up Rebuild w/ a Donor
#31
Fill the Mastercylinder up, pump the clutch, hold it to the floor, crack the bleeder screw.
Repeat until straight fluid comes out, no bubbles...Close the screw and go on.
#32
I spent some time looking over the frame today getting ready to get the engine and stuff off. I think most of the day tomorrow will be spent marking things and figuring out what I'm looking at, though I will try to get most of the electricals, vacuum, smog and other hose/wires off before I start removing components. I want to take my time and make sure I mark everything and get an orderly and organized disassembly.
Also, for the record, I've got between 16 and 20 hours of work in so far. Not bad for a first-timer.
#35
It does a LOT better job of getting the rust off, etc...
Ask Diesel_Brad
#36
Yeah, I bought a sandblaster from Eastwood just for this very job. I need to get my media ordered soon so it's here when I need it (probably go with an iron oxide), but obviously need something with some bite to get all the scale and rust off. Once it's blasted I'll assess the real condition of the cross members (some are really questionable) and probably order a few replacements. The front should be mint from all the oil that has been leaking from the engine and built up at least 1mm of junk.
POR15 is only the first step of my current plan. Once I've got a sold base down (not sure if I'll use a second coat since POR is really only good for metal contact) then I'll give it a good 'scratch coat' and hit it with Herculiner. I'm not positive that I'll got the extra mile with the bed liner yet, but I want something I won't ever (read EVER) have to worry about.
Of course, before I get there I'll need to get the engine and other parts off the frame and get it power washed at the local drive through car wash. I don't want the years of oil, grease and rust in my driveway, so I'll have to put it in my 7x14 trailer for the 1.5 mile trip. I'm sure I'll have pictures of that little excursion, but that's a few weeks out yet.
#37
Unless you have a BIG compressor, you are wasting your time with the sandblaster. I went down that road. I have a 35cfm(highly doubt anyone on this forum has one bigger) and it was not enough volume of air to Properly keep up with Eastwoods 110lb sandblast pot. Do yourself a favor and just take the frame to someone and have it done RIGHT. Your small pot id ok for small things but you will spend DAYS and 1000's of lbs of sand to do it right.
As for the POR15. I am a firm believer in the stuff as a base coat/primer. I then topcaot it while it is still tacky to get proper adhesion. Do NOT USE HURCULINER. Just use any high quality paint. I like tractor/implement.
#40
I'm curious why you don't think herculiner is a good option. I've been thinking it will be problematic for attaching things since any bolt or fastener holes would be noticeably smaller and establishing electrical grounds through Herciliner might be challenging... I'm just having some bad dreams about driving down a gravel road and hearing all the clinking and clacking chipping the paint off that I spent so much time on...
I don't think I've done anything too bone-headed thus far, but there's a long way to go. I'm not a huge fan of how I got the cab off (kinda ghetto) since it's not suitable for the reverse operation when I have a finished and painted cab... I'll need to find a better way to lift the cab high enough to clear the frame at some point during assembly- I have one interesting thought about an 'I' beam over the garage ceiling...
#42
#44
#45
