Help truck cutting out at low rpms
I just joined and am having a problem. At low rpms whether the truck is hot or cold my truck just cuts out, it almost sounds as if the truck is turning completely off, I'm not sure what this would be? I drive a 99 F250 Super Duty with the 7.3L in it. It's right at 188xxx. I talked to a buddy that works at the local ford dealership but works with the light duty gasoline vehicles, he mentioned it may be the HPOP, any ideas? Feedback is much appreciated.
Thanks!
Thanks!
Hello TKnight10 and welcome to FTE.
You should point your PC at the 7.3L Power Stroke engine forum. Those members can assist you with the care and feeding of the 7.3L PSD.
1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
RyanMackD55
01-16-2007 03:23 PM
