Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 12-06-2012, 03:21 PM
StatikPulse's Avatar
StatikPulse StatikPulse is offline
Garage is empty, add now
StatikPulse is starting off with a positive reputation.
Removing Crown Vic IFS from donor car
Curious to hear from those who have pulled their own IFS from a donor crown vic. My local (but still far way) pull-it-yourself yard has a few '03+ and I'm wondering how difficult it would be to remove the IFS? Do any other parts need to come out before it can be removed (like the engine)?
Thanks.
  #2 (permalink)
Old 12-07-2012, 04:29 PM
THartman THartman is offline
THartman is starting off with a positive reputation.
The engine mounts to the IFS. Make sure you get the rear control arm brackets. Depending on how you do the install, you may want to just cut the frame where the IFS bolts on.
  #3 (permalink)
Old 12-08-2012, 11:09 AM
Thanks, that's what I thought. That'll make it difficult to manage in a pull-it-yourself yard.
  #4 (permalink)
Old 12-09-2012, 09:49 PM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
2losteve 2losteve 2losteve
I was reading a post on removing a Jag IFS, which also has the engine mounted to the susp. crossmember, and it was suggested to find a bar to lay across the fenders. Then hook a chain to the engine and over the bar to hold the engine up while removing the suspension.
Steve
__________________
'56 F-100
'57 F-100
'54 Chev sedan del
'71 C-10
  #5 (permalink)
Old 12-10-2012, 04:08 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
Maybe you can buy the whole car and sell them back what you don't use and take you time doing it.
__________________
Walston
http://bigjohnstractor.com/
  #6 (permalink)
Old 12-11-2012, 12:37 PM
1959_f100's Avatar
1959_f100 1959_f100 is offline
1959_f100 is starting off with a positive reputation.
has any one installed the 4.6 out of the crown vic with the IFS. i am wanting to do this but havent been able to find any one that has done it.
  #7 (permalink)
Old 12-11-2012, 02:01 PM
I read a post where a person took the IFS, engine, trans, wiring harness/computer, etc and installed it all in a truck. Another one where they dropped the truck on the Crown Vic Frame.
For mine I have the Crown Vic IFS but the engine, trans, IRS and other goodies from a a Mark VIII.
  #8 (permalink)
Old 12-11-2012, 05:49 PM
1959_f100's Avatar
Mark VIII has the DOHC in it right
  #9 (permalink)
Old 12-11-2012, 06:36 PM
DOHC and the Teksid aluminum block. The Cobra (98-99?) had the same block but a forged crank and different cams on the intakes.
  #10 (permalink)
Old 12-12-2012, 06:49 AM
1959_f100's Avatar
how well does it fit in the truck.
  #11 (permalink)
Old 12-12-2012, 03:17 PM
1959_f100's Avatar
is there not an article on installing the crown vic IFS in the Article/Spec section. i saw alot of other IFS but not the crown vic. maybe someone should right one and pur it up there.
  #12 (permalink)
Old 12-12-2012, 06:43 PM
I will have pics of the DOHC in engine bay soon. Google Crown Vic IFS F100 and you should find several builds
  #13 (permalink)
Old 12-12-2012, 07:10 PM
http://www.ford-trucks.com/forums/10...s-build-3.html
Shows a IRS install
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
