Cooling system capacity 1976 Ford F150
Anyone know the cooling system capacity for a 1976 F150? The truck is 4x4, FE block, no A/C. Top tank on radiator measures about 2 9/16" wide by 3 1/2" tall, overall radiator is about 30" wide by 25 1/2" tall. Busted a hose and wanted to flush it out and refill since I'm also replacing the thermostat. Any help would be GREATLY appreciated, thanks in advance!
EDIT: should I use a 192* or 180* thermostat? Not super knowledgeable about FE's... Also, radiator is 19 3/8" between tanks.
OK update, thought I'd pass this on... there are two radiators for FE engines this year, a shorter one that is 19 3/8" tall between tanks, and a taller one that is 24"+. The taller one is for the "heavy duty" cooling, like if you have a/c, bigger truck, etc. Most have the smaller radiator, and total capacity is 22 quarts. The larger radiator holds two more quarts, 24 quarts total. Difference being that you buy 3 gallons of straight antifreeze, w/o hd cooling you have a quart left, with h/d cooling you use it all. Thought I'd pass it on. This is apparently the same for all F-series pickups, 73-76, with an FE engine.
'Dunno the exact capacity but I know it'll need at least two gallons of coolant.
Here's what I do...
With the thermostat, I like to drill a 1/8-inch hole so there is no trapped air in the block.
I'd go with the 180° thermostat.
Here's what I do...
- Starting with an empty cooling system and the heater controls set to hot, dump one gallon of pure coolant.
- Refill the empty jug with water and pour it in.
- Now you should have an empty container and one full container.
- Pour one-half of the full gallon onto the empty container.
- Fill both of them with water.. now you have two gallons of 50/50 mix.
- Dump one gallon in and use the other to top it off.
- Fire up the engine and monitor the coolant level for when the thermostat opens.
- Top off one inch below the neck to allow for additional expansion.
- Mark the jug with "50/50" so you know it's a premix. Stick it behind the seat and you're good to go.
I have the smaller radiator in my 150, so I put 11 quarts in my truck based on my research, and topped it off with water. Ran the truck a good couple hours altogether and checked the coolant the next day with a tester, it was good for -34*, or 50/50 mix. Used the 180* thermostat, heater works fine and the engine warms up nice.
casper1999
1983 - 2012 Ranger & B-Series
27
02-27-2019 04:38 PM
SoCalAngler
07-12-2014 05:28 PM
rustyranger390
28
08-20-2011 01:39 PM
