the great chase
the great chase
Hey guys, In september I bought a 1994 ford f150 4x4 super cab with a 150,000 mile 5.8l and automatic. It has the waldoch conversion. Now, It is not getting the fuel millage that i was expecting. The best i have gotten is 240 miles out of just shy of 17 gallons of gas. so, I am in search of at least couple more mpg. It is completely stock. it has 3.55 gears according to the window sticker. Will a K&n anything help? dual exhaust? single exhaust with a flowmaster 70 series? I do know it's in need of a tune up due to a twitchy idle. any help will be appreciated.
14 in town? I consider that pretty good for that truck(4x4, auto, 351).
I just put shorties and true duals on my '89 302/aod/3.55 2wd truck. I haven't had the chance to get a road trip to see if it increased mileage on the highway. Around town it's about the same so far, around 14. Completely stock,130K miles, including air filter.
on
14mpg isn't bad but not exceptional. I would not suggest larger diameter tires if you live anywhere that isn't flat in all directions, 3.55 gears and only 4 forward speeds produces a lot of downshifting on hills and that kills fuel milage. The single best thing you can do for milage without going inside the motor is fit longtube headers and a single 2.5" exhaust system(mendrel bent tubing), if you have a muffler shop create it then 3" tubing produces the same result after factoring in the compression bends.
P.S. What does a waldoch conversion look like on a pickup?
