Like the looks of the truck. I ain't so much into the 20s..bit everybody has their own tastes I think for the look you're after..slimmer would look a tad better
That grey stuff on the floors is rust-stop, which was sprayed on to halt the spread of what rust was there.... Sanded the rust, then washed with soap and water, then spray with rust-stop.
I might leave the dash bare.. gives it a nice custom-clean look. It will need some custom work to incorporate other ideas I have for the truck.
I'm going to be painting the door inserts soon too. Then work on getting a replacement seat or a custom set-up and some carpet.
What are some ideas for sound deadening in the cab area? My thoughts are a spray-type liner or some adhesive mat-type material... Just not sure which would be most prudent and logical.
