Need OT help
Need OT help
I am restoring a amusement park ride from the early 60s.It is a Thunder Alley Car,That would of run on a paved road ,It had a 5hp briggs.It used a small auto or golf cart rear end with a backing plate attached to the pumpkin and the brake drum bolted to the yoke it used a 1 inch wheel cyl I need the wheel Cylinder.Anyone ever worked on one or know where I might find parts.I have tried matching it up with a old timer at his parts store with no luck.
First I never learned how to post pictures on this site,Maybe I will have to try.I did find a company in Utah named Arrow,They tell me they made this ride up until 1972,The last time they had requests for parts was 1989.They said the original brake parts are no longer avabile,But they would look for build sheets and other information and send me copy's.I thought that I had found a cyl from a 50s nash or 63 jeep that would work,but after getting it ,no go.I have sent the original cylinder to my brother, that runs a machine shop and he called tonight a said he was able to repair it.I will try to get some pictures up.I want to get it up and running for the next truckstock.In case Docs kids need a new ride.
Try this...
Go to http://photobucket.com/ and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Or just follow Joes advice.
So I don't know where you got any of that information, but it is all wrong.
on
Here is some more options. Including Joe's
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
The best photos and videos | Photobucket
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
