Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 12-01-2012, 08:23 PM
BonesJones BonesJones is offline
Garage is empty, add now
BonesJones is starting off with a positive reputation.
Question 63 F100 uni 223. My first resto = Help
Hello, new here to the forum and have already picked up a lot of good info before my first post. Long story short, got a 63 uni hand-me-down from the grandpa, he wheeled and dealed it off someone so no sentimental value to him. Had the truck about a year and a half. Pulled it out of his field, got it home, threw some gas in the bowl and fired right up. Can't kill an inline 6. Eventually I sold it. Then I bought it back. Got it running, drove it, broke down, parked it and let it sit for a while. Now I got my motivation back and I'm trying to finish it out. It will never be an all original truck but has great potential to be really nice. I've ran through all the fuel lines and found a tank and seat out of an old dump truck. I'm still having problems with getting the idle set on the carb. Carb has been rebuilt and I stay away from ethanol. When I do get the idle set, it will idle all day, but when I drive down the road and let off the gas coming to a stop it wants to die every time unless I have the choke pulled out a certain amount. Can anybody throw a dog a bone on this one. I have plenty more questions to come but first things first. Thanks
  #2 (permalink)
Old 12-01-2012, 08:27 PM
kjvforme's Avatar
kjvforme kjvforme is offline
1962 Ford F-100
kjvforme has a very good reputation on FTE.kjvforme has a very good reputation on FTE.kjvforme has a very good reputation on FTE.kjvforme has a very good reputation on FTE.
Is it running the Holley H-1 or the Ford (Autolite 1100)? Welcome to the FTE!
__________________
Rob
1962 Ford F100 flat bed 4x4, 223, 4spd.
1962 Ford F100 Unibody with Olds 330 & Jetaway
1944 Ford GPW (Jeep) with 1947-48 Willys L-134
To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 12-01-2012, 09:10 PM
Thanks Kjvforme, it's running the holly.
  #4 (permalink)
Old 12-01-2012, 10:38 PM
kjvforme's Avatar
1962 Ford F-100
If you have a tach, the Idle should be at 500-550 for manual transmission, and 475-525 for automatic. When you get it to Idle have you adjusted out the idle mixture? If so check that the chock lever is making the choke plate all the way open and is verticle. If it is not loosed the screw that retains the chock cable, push the **** all the way in. Move the lever to ensure the chock is all the way open and tighten back up the cable lock screw. Then adjust the idle once again, and the idle mixture.
A couple of things to check is carb tight to manifold and loose throttle shaft in the carb base, this causes vacuum leakks that will make adjustment difficult.
__________________
Rob
  #5 (permalink)
Old 12-11-2012, 08:55 PM
pburress's Avatar
pburress pburress is offline
1963 Ford F-100
pburress is starting off with a positive reputation.
You could have an air leak somewhere between the carb and cylinder. If the carb was off for the rebuild, did you replace the gasket underneath?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
