1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
1999 f250 dome light, door ajar?
Old 12-01-2012, 08:05 PM
catscratch's Avatar
catscratch
catscratch is offline
Door ajar and dome light stays on until the truck gets to 15mph, then comes back on when you slow below 12mph or so. WD-40'd all latches... Started doing it after washing the truck this afternoon.
Thanks for any help.
Jason.
Old 12-01-2012, 09:47 PM
garmford's Avatar
garmford
garmford is offline
There is a $20 switch in the door. Mine went faulty once. A bit tricky to get at but it is doable. gl!
Old 12-01-2012, 10:52 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
Jason.
You can keep trying to clean/lube the latches. But I would check for water intrusion, near the GEM/fuse panel area as a possibility.
You might have a leaky windshield(pretty common actually) or leaking cab lights if you have them.
With any luck though, it may dry out and work fine.
Old 12-03-2012, 06:42 AM
catscratch's Avatar
catscratch
Well guys, the dome light and door ajar returned back to normal (either the WD-40 worked or the GEM dried out) but now the driver's door won't stay shut and I have to slam the hell out of it to get it shut. I guess the lubricant made something in the latch too slick! Hopefully it will come back to normal without having to adjust the door because it was perfect before.
Thanks for the help.
sbappleg8
1983 - 2012 Ranger & B-Series
15
08-02-2017 11:45 AM
CobraGT40
20
01-15-2011 09:08 AM
socalarcade
12-12-2010 05:17 PM
kawboss
1997 - 2003 F150
01-08-2008 06:46 PM
Ultramagdan
1997 - 2003 F150
12-04-2002 04:06 PM
Quick Reply: 1999 f250 dome light, door ajar?
