Cutting off exhaust manifold studs
Old 11-25-2012, 08:07 PM
jprix's Avatar
jprix
jprix is offline
Please explain how you guy got enough clearance to be able to cut off the exhaust nuts. Obviously remove wheel/wheel well,but did you guys lift motor? Remove starter and or ac compressor?
Im working on my 5.4 98 Expedition(pass side),using an angle die grinder but cant find the room.
My last step is just to call my buddy over and plasma cut the manifold into peices to get access.
Old 11-25-2012, 09:34 PM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
What I used 2000 5.4 f150
Old 11-25-2012, 09:56 PM
jprix's Avatar
jprix
jprix is offline
What kind of bits are those? Did you lift motor or remove anything?
Old 11-26-2012, 06:18 AM
kbsupercrew
https://www.ford-trucks.com/forums/1...-possible.html
This post is when I had to cut off my manifolds to put on headers
Old 11-27-2012, 12:32 PM
jprix's Avatar
jprix
jprix is offline
How long did it take you to grind then off?
Old 11-27-2012, 05:22 PM
kbsupercrew
If I remember right it was about an hour and a half a side, I had to cut off the flange studs as well
landscapeguy
6.2L V8
08-14-2019 08:52 PM
72cougarxr7
1999 to 2016 Super Duty
01-24-2019 08:33 AM
twigsV10
07-30-2015 12:45 AM
79whitetrash
Modular V8 (4.6L, 5.4L)
08-21-2010 08:09 AM
Robs98f150
1997 - 2003 F150
04-06-2004 09:36 AM
Quick Reply: Cutting off exhaust manifold studs
