problem with 4WD on 2004 F150 FX4
Old 11-25-2012, 10:24 AM
tstandish's Avatar
tstandish
tstandish is offline
When actuating the 4WD unit getting grinding noise and won't go into 4WD-does anyone know what might be the issue?
Old 11-25-2012, 01:08 PM
JoSHN's Avatar
JoSHN
JoSHN is offline
This link will probably answer everything you need to know.
https://www.ford-trucks.com/forums/8...then-some.html
Old 11-25-2012, 01:50 PM
tstandish's Avatar
tstandish
ok-thanks much-deer season upon us-may have to work on truck in a couple days-will check out the link
Old 11-25-2012, 09:36 PM
Winter Brew's Avatar
Winter Brew
Winter Brew is offline
JFYI.....if you need the hub actuators, they are $62 on Amazon....same mfr and appear identical to the $120 and $180 units. The Solenoid I would go Motorcraft as well as the the check valves. Keep in mind if the actuators are worn down from grinding, there is something in the vacuum system that caused it so its important to find the cause before ruining the new actuator. I learned the hard way.
ajonesnv
2004 - 2008 F150
06-22-2017 10:59 PM
pattece
2004 - 2008 F150
11-14-2013 02:10 PM
walt j
2004 - 2008 F150
01-08-2012 09:45 AM
JRROTH1
04-05-2010 09:11 AM
BigTonyG
1983 - 2012 Ranger & B-Series
09-18-2006 01:11 PM
Quick Reply: problem with 4WD on 2004 F150 FX4
