Vacuum Line ells 97 F250 7.5
11-24-2012, 04:53 PM
Hi new guy here.
Where do you get the 2 rubber ells that hook the pcv line to the back of the intake on my 1997 F-250 7,5? I stopped by my local Ford dealer and parts was no help.
Thanks
Glen
11-25-2012, 07:55 AM
11-25-2012, 03:30 PM
Thanks "but"
I guess that a Calif truck is different. The line goes from the intake to some sort of switch on the fire wall.
PICTURES
Is this still available?
Having a hard time with Ford parts....
Glen
11-25-2012, 03:46 PM
But wait!
What is the number on that tag? That tag still being there should lead a real Ford parts tech right to it!
Also that line you show should only be going from the intake to the Vapor Management Valve. (or Vapor Storage Valve) That's not the PCV line.
11-25-2012, 03:47 PM
Quote:
Originally Posted by
ncranchero
What is the number on that tag? That tag still being there should lead a real Ford parts tech right to it! WTH???
Also that line you show should only be going from the intake to the Vapor Management Valve. That's not the PCV line .
X2
11-26-2012, 01:18 PM
Tag on Line F9TE-9G271-EC
11-26-2012, 01:44 PM
NumberDummy could probably find that for you, you can try to PM here on the boards.
11-27-2012, 12:14 AM
Well,,, Went to the ford parts counter again and they said that the part is no longer available. I guess that I will just use a piece of Vacuum Hose or is Fuel line better?
11-27-2012, 12:20 AM
Well.. Went to the ford parts counter at my local Ford Dealer. They said that the part was no longer available.
So now I am going to replace that VMV line to intake manifold with either fuel line or will vacuum line work?
11-27-2012, 02:34 AM
11-27-2012, 10:32 AM
Thanks. That one is not right. The hose runs from the back of the intake tower to the VMV valve.
Glen
11-27-2012, 05:05 PM
Glens67
Glen
Yes, I know.
ncranchero
From my Ford Tech
"STEVE, FORD EMAILED ME BACK SAID NEED VIN# BUT PART # WOULD NOT CROSS OVER RECHECK #"
Want to post, message or email me the VIN?
11-27-2012, 05:14 PM
PM on the way
Thanks for the help
Glen
11-27-2012, 05:21 PM
Got it and will forward it to him.
11-27-2012, 05:56 PM
