Finding Correct Speedo Gear
So I was trying to Follow Garys lead on this thread:
https://www.ford-trucks.com/forums/1...nion-gear.html
But I couldn't find my original tire listed in the master parts catalog, all the listings were for 16.5 not 16's
These are for the 4.10 out of the parts catalog
Still Running 235/85/R16's
Heres my sticker
So I got the original tires, I got a 4.10 rear ratio, and a T-19 4-speed warner transmission. Should be pretty easy, but we all know how that goes.
Thanks Again,
Devin
Heres my sticker
Thanks Again,
Devin
Yes I did answer my own question, and yes I figured out the counter clockwise bit.
The bad is that after hooking back up I still have no speedo
Anyway according to what I have read, the drive gear is the next step?
How do I find a part number on that ? is it actually called drive gear?
Devin
Devin
Three places to focus on. The gear that's in the transmission or transfer case, the gear that's on the end of the speedometer cable, and the gears inside of the instrument cluster.
If you pull the cable and gear out, you should be able to look in and see the gear inside the transfer case or transmission that drives the cable. This is the drive gear. The gear on the end of the cable is the driven gear. Then you've got the speedometer gears in the cluster.
If the gear on the cable and in the hole looks good, then you might want to check out the gears in the instrument cluster.
The drive gear rarely goes bad, and changing it isn't easy. You should be able to see it through the hole the driven gear goes through.
Did the speedo work originally and quit? Or, was it not working when you bought the truck? If the latter, you may have the wrong speedo gear, as in one for another typ of transmission. Are there any numbers on it?
Heres my sticker
Thanks Again,
Devin
Heres my sticker
Thanks Again,
Devin
