89 F250 Power Steering
Fill it up, start it up, & turn the wheel lock to lock a couple times. Re-fill if necessary, and hopefully the pump wasn't damaged from no fluid.
I've had a couple lost caps over the years. After re-filling, the pumps made more noise for a little while, but then settled down and worked fine.
I'm not sure if your PS is set up just like mine, but if you want to flush new fluid through it a couple times: the back of the reservoir has a rubber hose held on by a spring clamp. It's easy enough to drain the whole reservoir at that point and refill without draining the whole system and introducing air. After a couple drain/fill/drive sessions you will have almost all new fluid in the system.
78mudslut
25
04-06-2006 04:22 PM
