2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Finally Changed the Plugs
Old 12-02-2012, 05:11 PM
thinksnow's Avatar
thinksnow
thinksnow is offline
I took the plunge this weekend and changed the plugs. I was starting to experience a miss and my mileage was going in the crapper, worst then usual that is. I went with the seafoam induction service / impact wrench with a engine. All went well. I switched over to the champion double platinum plugs with some anti seize on them. The only place I couldn't get the impact wrench in was the passenger side rear most plug. It was tight back there; ended up just using a 3/8 ratchet. Thank God it was willing to come out.
Old 01-02-2013, 06:53 AM
Bopper's Avatar
Bopper
Bopper is offline
Congrats. What was the mileage at the change? Hows it been running since?
Old 01-10-2013, 07:03 PM
thinksnow's Avatar
thinksnow
Changed at 111k. So far so good. It's running great on the champions.
Old 01-26-2013, 01:07 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
i have thoughgt about going with the impact wrench to remove mine aswell. Did you soak them in anything prior to using the impact?
Old 01-26-2013, 03:03 PM
thinksnow's Avatar
thinksnow
I didn't but some guys have said they unscrew them a 1/4 to a 1/2 turn then spray PB down the hole and let it sit overnight. I only did the sea foam induction.
Old 01-26-2013, 04:23 PM
kailor's Avatar
kailor
kailor is offline
Do the 07 and up Expeditions have the 2-piece plugs?
Old 01-26-2013, 04:35 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
i think so. Ive heard alot of things about them nreaking off in the heads
Kai Herrmann
06-27-2018 12:01 PM
Utah F250
1997 - 2003 F150
02-13-2011 10:46 AM
mswpj
2004 - 2008 F150
09-07-2010 09:28 AM
tcesni
Escape & Escape Hybrid
06-03-2007 10:52 AM
kevinken
1978 - 1996 Big Bronco
03-30-2003 01:38 AM
Quick Reply: Finally Changed the Plugs
