Instructions to swap in head studs 1 by 1 ?
Well I had quite a scare a while back, I thought I toasted my HG's.
The cooling system on these things is insane how touchy it is.
After getting if flushed a few times, cleaned, and several attempts to get the right fluid level, it's finally good.
For a few months now, it is sitting at the same cold spot level, and several attempts have been made to cause it to puke coolant, and it won't. It holds 40 psi of boost up giant hills and stuff, level remains the same.
So I am contemplating swapping out the stock bolts for aftermarket head studs. It seems nothing is wrong with the HG, so theres really no point in pulling everything apart.
I am wondering if anyone here has done this, and what instructions did they use?
I suppose would be a good time to delete EGR, and air intake elbow?
Any intake elbows that will work with stock airbox?
I get where you're going, but like I said, it's been 3-4 months now, not a drop of coolant missing, no cooling system issues. Holds 40 psi of boost many many times, obviously theres nothing going on........
Got bit by the Power Bug did ya? The stock bolts should be fine until you add more and then a little more. I am with Senix, leave it alone but I am not saying one by one will not work. Expect the unexpected.
The bigger tunes just drive nice and get good mileage.
They also have no safety built into them, so you could easily blow you're HG just passing a car.
I'm pretty sure I stretched my head bolts, a while back it was puking, and that wast on the 275 tune.
I talked with several people now, and it seems to be it it's holding together on the 150 HP tune, not exceeding 40 lbs of boost. The consensus goes that the bolts are stretched a touch, and the HG's should be fine.
This makes sense, like I said, it's been months now, not a drop of coolant gone.
On the bigger tunes, the 6.4 turbo's are small enough that even with the VVT opened right up (not trying to boost), the turbo's can run away up to 60 lbs, and that is HG killing boost on these.
I never drove it that hard, and I fixed it quick, so I don't think anything is wrong except the TTY bolts maybe a touch stretched.
I'm in the same exact boat... i de-tuned to 210 and am fine. Ran it real hard, parked, and saw no signs of puking. I'll research, as I'm also going this route.
I've done plenty of head gaskets, and when they are done, they are DONE. I'm not willing to remove/replace the whole top end when i'm clearly not showing signs of warpage, didn't overheat, or the like.
I'll let you know if i find anyting in my searches, and please do the same if nobody volunteers such info here first!~
Yeah I see no reason to do extra work, it it's holding with a lower tune, maybe the studs just stretched a touch, no reason to do a cab-off.
Mine hasn't lost a drop in months, and holds 40 psi no problem up big hills, towing etc. I have zero worries about my head gaskets, they're obviously fine.
How many miles are on your truck? If its higher mileage, just do it right. There is a write up on PSN or PSA, can't remember for 1 at a time replacement. In my opinion, just pull the cab and do it right. I have 80k miles on my truck and have run the 275-310 tune as a daily driver the last 15k miles with no issues. Seen 53 psi of boost with no puking.
If you stretched the head bolts then obviously the seal has been compromised. Bite the bullet and do it the right way.
150hp tunes are 50-60hp less than most tuners "tow" tunes. Put the big tunes on it and see how she does. That will let you know quick.
I would not be surprised if the thing puked running the 275 or 310 again, and pegging the boost to 60 lbs, I think 1 or a few of the head bolts might be stretched, but I doubt the HG's are toast as it's held on this long.... my train of thinking, anyways.
