Need front hubs for 1954 F-250
Hi,
I'm new to the forums and need some help. I have a 1954 F-250 that has received a front disc conversion. Unfortunately it was also converted to 5 lug, only up front.
I want to convert it back to 8 lug, however cannot find anyone selling these hubs. I have already located an 8 lug disc brake conversion, but it requires the original hubs.
Any ideas?
Any ideas?
are these the brakes you found?
Ford F2 & F3
I remember another guy that was thinking of going down to the 5 lug from the 8, worth a shot, here's the thread
https://www.ford-trucks.com/forums/1...250-build.html
there is also this option . . .
https://www.ford-trucks.com/forums/1...p-85-f150.html
More info
Installing Disc Brakes on Your 2WD Pickup - Pt. 1 - FORDification.com
F-2/F-3 Front Disc Brake Conversion
This is all the info i have found on front disc brakes, I have a set from the street rod mfg, not installed yet.
Could try calling them up and see if they know of an alternative.
Ford F2 & F3
More info
Yes, those are the brakes. It seems to be the most straight forward way to go.
Thanks for the input.
I posted on the thread you mentioned. Hopefully he'll sell them to me.
I want to avoid any custom machine shop work in order to not have my truck apart for a long time.
Hopefully some others may know a bone yard that has these parts?
I have to pull the wheel off and look at the spindles. If they were modified I may want to buy those from you as well.....
robbyriot
03-27-2015 12:56 PM
Mtphammer
07-19-2014 04:46 PM
richlars_7
12-13-2002 08:05 PM
