removing EEC-IV from my truck
Old 09-01-2014, 10:41 AM
dylansf23's Avatar
dylansf23
dylansf23 is offline
do i need this in my truck anymore?
all i need is the ignition wire for my all in on distributor
what about my computer under the dash?
Old 09-01-2014, 02:56 PM
fordboy300's Avatar
fordboy300
fordboy300 is offline
No and no! Hoped that helped I still have both of those still in my truck but there just hanging out lol
Old 09-01-2014, 06:43 PM
dylansf23's Avatar
dylansf23
How about the computer that all those wires lead to under my dash?
Old 09-01-2014, 07:56 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
The second one is your voltage regulator and has nothing to do with the ignition system. No idea what the dude above me is talking about. If you take it out, you can thank that guy for your truck not charging.
I can't answer the rest of your questions unless you explain what it is you're actually working with.
Old 09-01-2014, 08:02 PM
dylansf23's Avatar
dylansf23
I'm removing all the wires.
I have an all in on distributor from dui.
I'm dropping a built motor in and trashing the feed back system.
Old 09-01-2014, 08:32 PM
fordboy300's Avatar
fordboy300
Well actually I thought the second photo was the truck's computer. So that was my reason for saying no.
Old 09-01-2014, 11:28 PM
lostonmonday's Avatar
lostonmonday
lostonmonday is offline
Swap in a 92 Taurus alternator and you won't need the second pic :-)
Old 09-01-2014, 11:30 PM
dylansf23's Avatar
dylansf23
I'm picking up a 97 f350 parts truck and I plan on taking the heavy duty alternator off of it
Old 09-02-2014, 10:24 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Nope. Voltage regulator. See the connector? I, A, S, F: ignition (charge light), alternator (sense), stator, field. It is required unless you swap in a later-model internally regulated alternator, such as a 3G.
The second one looks like a MAP sensor. Your DUI distributor won't use it. I've only seen those on EFI vehicles; I'm less familiar with the feedback system. But it would have been part of that. If you've got a standalone carburetor and all-in-one distributor, you don't need a MAP sensor.
Old 09-02-2014, 04:57 PM
dylansf23's Avatar
dylansf23
How can the second one be two things?
Old 09-02-2014, 06:07 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
I don't understand what you're asking. The first picture is a MAP sensor. The second picture is a voltage regulator. Neither is a computer. That is all.
Old 09-02-2014, 06:10 PM
dylansf23's Avatar
dylansf23
Your last post said. " The second thing is" twice. I was confused.
Is the feedback computer not under the dash?
Old 09-02-2014, 07:18 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Whoops, sorry for the confusion. That post should have said "first one." I think you know what I mean though.
Under the dash would be my first guess at the feedback carburetor amplifier. You'll have to look.
Old 09-03-2014, 03:38 AM
dylansf23's Avatar
dylansf23
Okay I just wanted to make sure.
Yes I do bekive that is where it is. I haven't gotten to that point yet. I have to work on it on weekends after a 4hr drive up from base so my motivation is slowly dwindling:/
Motor should be done soon tho!
Old 09-03-2014, 08:42 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
The "feedback" computer is indeed under the dash, to the left of where the ash tray is located. It is mounted vertically.
On the engine side of the firewall, there is a large bundle of wires going through a rubber grommet. Just follow the wires and they will lead you to the computer.
As you remove these items [i.e. MAP sensor, computer, etc.], save them in a box because from time to time, there will be someone on the forum looking for these parts and you can help them out!
Quick Reply: removing EEC-IV from my truck
