Minnesota Chapter Join Chapter, Leader: fordpower88
No-No-November BS Thread
Old 11-15-2012, 02:41 PM
wildstang's Avatar
wildstang
wildstang is offline
VT Chapter Ldr
Nope. We used to own an 98 a4 Audi. Handled really good. That's the only nice thing I have to say about that POS
  #752
Old 11-15-2012, 02:46 PM
Devious Delight's Avatar
Devious Delight
Devious Delight is offline
which motor? quattro? standard?
  #753
Old 11-15-2012, 02:52 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
1.8 Turbo quattro with techtronic auto
  #754
Old 11-15-2012, 02:57 PM
Devious Delight
1.8Ts are solid, if maintained. what problems did you have with it?
  #755
Old 11-15-2012, 03:04 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
The expensive maintanence, eats up wheel bearings like a crack head does cocaine, St the end it ran like crap, mechanic couldn't figure it out so traded it towards an 05 ford five hundred
  #756
Old 11-15-2012, 03:22 PM
Devious Delight
sounds like a terrible mechanic. the a4 chassis isn't all that different from your Jetta.
I had one in a passat. they are picky though. synthetic oil, and premium gasoline- both are musts.
  #757
Old 11-15-2012, 03:33 PM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is offline
  #758
Old 11-15-2012, 04:39 PM
msmenne17's Avatar
msmenne17
msmenne17 is offline
Originally Posted by DieselCamper01
Dunno ... that's as much as I know. Glad I wasn't here. That's the building my palace errr.. cube is in.
  #759
Old 11-15-2012, 04:43 PM
msmenne17's Avatar
msmenne17
The last statement by the DOT in this article baffles me.
Signs changed after highway death » Local News » The Free Press, Mankato, MN
"Arndt said they were removed because motorists were running the [stop] signs"
WTF? People are running the signs, so you just remove them? Well ... here ya go. Someone is dead because of it.
Hwy 14 west of Mankato is a death trap. Katie works in New Ulm and avoids Hwy 14 if at all possible.
  #760
Old 11-15-2012, 04:47 PM
msmenne17's Avatar
msmenne17
Afternoon everyone. Busy day. I've logged in 3 or 4 times today to read through yesterday and today and post. This is the first I've been able to finally do that. And ... I've got class in just over an hour. I'll probably be sluffing off trying not to fall asleep.
  #761
Old 11-15-2012, 05:55 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
They turned it into a 2 way from a 4 way stop?
  #762
Old 11-15-2012, 05:56 PM
msmenne17's Avatar
msmenne17
No. They turned it from a 2 way stop to a NO WAY stop. They took the stop signs out.
  #763
Old 11-15-2012, 06:10 PM
FORD RANGER's Avatar
FORD RANGER
FORD RANGER is offline
hey guys,
that don't sound good.
  #764
Old 11-15-2012, 06:17 PM
msmenne17's Avatar
msmenne17
I've tried fixing the end of the shifter on my truck twice now. Both times, it's broken in two days. I tried JB Kwikweld both times.
What else can I try? I don't think JB Weld will work since it's essentially the same as JB Kwik, just a little stronger. Kwikweld should have been good enough. I let it sit overnight both times. I don't think it's bonding to the plastic very well.
  #765
Old 11-15-2012, 06:29 PM
FORD RANGER
ford uses some secret glue to keep then from coming off. the shift **** kept coming off on my ranger and annoying. finally i used wheather strip adhesive and that worked out pretty good so far. atleast it on there still.
Quick Reply: No-No-November BS Thread
