Clutch release bearing question
Old 11-05-2012, 04:23 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
59 1959 Ford F Series Release Bearing - Clutch - National, PartsMaster - PartsGeek
OK so I decided to do a complete clutch job before installing my engine and trans. The question concerns the parts in the link. What I removed looks like the top part and what I got with my kit looks like the 2nd part. My engine man seems to think I just need to use the new bearing (2nd part) on the old hub without the rest of the assembly. I'm not the kind of guy who wants to install a freshly overhauled engine with a new clutch and a resealed trans only to pull it back apart. Any ideas?
Old 11-05-2012, 07:35 PM
spurredon's Avatar
spurredon
spurredon is offline
Your engine man is right. Just replace the release bearing, no need to replace the bearing hub unless it is damaged. It's job is to hold the bearing in place when the clutch is released. So if no obvious damage, just clean it up and press a new bearing on.
Old 11-05-2012, 08:16 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Thanks. I was able to get the old bearing off the hub without much effort using a drift and a hammer. Is that too loose?
Old 11-06-2012, 04:55 AM
Walston's Avatar
Walston
Walston is offline
Yes you want to use the old hub. The hub fit is not that tight. If I remember correctly, it has been a few years since I did this, there is a lip on the hub that fits against the bearing. Tap it into the new bearing and you are good to go.
Old 11-06-2012, 09:14 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Thanks for the info. I did notice the bearing is made in such a way that it slips easily onto the hub when you install it backward and requires gentle pressure to push it on correctly. The designer must have done this so people with common sense would not install it backward
MrGonads
05-18-2017 10:28 AM
scottddove
08-12-2015 12:48 AM
artieb
Escape & Escape Hybrid
11-04-2013 07:43 AM
john fin
06-29-2011 11:47 PM
yotazuki
1999 to 2016 Super Duty
08-01-2009 09:46 AM
Quick Reply: Clutch release bearing question
