Emergency tire inflator questions...
Guys, I just bought new (used) tires Friday and today, I came out of a store only to find a flat tire. Apparently I got a nail or screw in one of them.
As luck would have it, there was a dude almost right next to me who had a small portable compressor and he helped me out
So, my question now is, what are some good options for emergency tire inflation so to speak and is that gooey stuff you can spray into the tires to seal them good or bad for your tires and what are the pros and cons of those?
Will this create a problem when you later go in to have the tire fixed?
What about co2 inflators and how much would it take to pump a 265/75 R16 tire to around 45-55lbs?
As always, links are very helpful.
I've looked at co2 inflators but then, I don't know if they are for bicycle valves or trucks or what?
Thanks
Thanks
I bought a Canadian tire jumper kit. It has I think 1,000 cranking amps, can be charged off of 12/120V which is super convenient, has an air compressor and air gauge as well as an led light and USB plug. Very worthwhile and always behind my second row seat!
Never know when you will need a jumpstart or a tire inflation just to limp home, and maybe no-one is around
on
Thanks
Thanks
Well, I got a jump starter although I lent it to someone and he said it didn't work so gotta look into that but found one that was very highly recommended (as a jump starter at least) which had a compressor and I also found a compressor that was super highly recommended for a little more money.
I don't mind spending a little more for good stuff and hell, I could buy both and keep both in the truck.
As for the tire repair kit, I'm too stupid to follow instructions but I could get a buddy of mine to show me how to do it.
What's the word on the goo stuff that you can spray in the tires together with air and anyone know anything about the co2 kits and how much it takes to fill one of our tires up?
Fix a Flat or Slime and a ViaAir portable compressor works for me. I forget which model I have but it's one of these:
Amazon.com: VIAIR 85P Portable Air Compressor: Explore similar items
What's the slime stuff? Sounds like goo but they also have compressors on amazon so wasn't sure if that was it. If it's goo, have you used it and what's the word on that stuff?
Thanks
I have used plenty of Fix-a-flat type stuff (spray can tire sealant) over the years. I have them in each vehicle and have told my wife to use that rather than trying to change a tire on the side of the road. They work just fine for sealing leaks and getting the vehicle back on the road. Tire shops don't particularly like them because the sealant has to be cleaned out of the tire when the tire is dismounted later. I worked in a tire shop and it was not really a big deal. For a 265 or larger tire, you would still need more inflation to get up to full tire pressure. I haven't used CO2 inflators on anything so I can't speak to those.
I carry a plug kit from AutoZone and one of the battery jump boxes with an air pump in it. Since I started carrying this I haven't had a flat or dead battery. The plug kits are less than $10 and Costco sold mine for under $70. The little pumps are great for one tire but you definitely will not be able to air up 4 large tires after a day off roading without burning up a pump or two. CO2 bottles are real common with Jeeps out here but I am not sure I would want it inside my Ex all the time. One CO2 bottle is good for 8-16 airups.
on
