PROBLEMS STARTING A 1995 F800....
Ok....so I took the truck to the dump, dumped out the load, went to the gas station to fill it up, and it will not start!! I had a guy, with another diesel truck try and jump it, but to no avail. Drove the damn thing all day, yesterday, with no issues!!??
The starter is cranking real slow, and not a full rotation. Went and bought a new starter, while waiting for a bigger tow truck to tow it for me. Put it in, and the same thing.
Not to mention, the back brakes are locked, since it will not start, to release the parking brake. I'm not to worried about that.
The only real odd thing that happened, is, while jumping it with the other truck, when we tried to start it, the trottle lock cable began to smoke!!
Someone said to check all the grounds on the truck??
I am at a loss.....any and all help is highly appreciated.
Thanks,
Goodwood
Thanks,
Goodwood
Ok....
The starter is cranking real slow, and not a full rotation. .......
I am at a loss....Thanks,
Goodwood
Goodwood
Once you fix the grounding problem you will most likely need a new throttle lock cable as well.
abe
03-23-2015 10:26 AM
tallinboy
09-26-2010 09:28 AM
elstx
10-02-2003 08:24 AM
Pkupman82
09-20-2003 07:56 AM
