Need help with 92 f-250 speedometer
I HAVE A 92 F-250 THAT THE SPEEDOMETER QUIT AND THE ABS LIGHT CAME ON AND THE TRANSMISSION DOES NOT SHIFT RIGHT.
460 CID AND 2 WHEEL DRIVE.
NOTE: THERE IS NO VSS ON THE SIDE OF THE E4OD TRANSMISSION.
ANY HELP WOULD BE GREATLY APPRECIATED.
THE ODOMETER IS ELECTRONIC
Could be several things. There is a tone ring inside the diff housing that the VSS is triggered by, may have to check that the ring is intact.
However check the condition of the wires from the VSS righ up the frame rail, remember some guys finding chaffed wires on frame around the trans crossmember, I think.
The RABS module is behind the glovebox, you could try unplugging the electrical plug from it and see if you get the speedo and trans back.
It could be that you have a bad PSOM (behind instrument cluster). Enter psom in the search box for more info on that.
I don`t envy you the problem, can be a huge PITA.
Hopefully some of the real experts will give an opinion soon.
It is important that you get this sorted to protect the trans from extra hard shifts, so don`t give up on it.
Fuel Injection Technical Library » How To Run a Self-Test Here is a link on how to check for trouble codes. However it would be unlikely you will get anything other than a VSS fault code. Code meanings from list on right.
A nightmare indeed.
A nightmare indeed.
Still need some ideas on this problem
Well, the speedometer is still dead, the "ABS" light still on and I have changed out the VSS on the differential and have checked every fuse that was even close to the one for the odometer. I have not zeroed in on the PSOM in the instrument cluster yet.
Does anyone know of a test that could be done to isolate this problem?
One test is worth a 1000 opinions?
Here you go:
CHECK SPEED INPUT SIGNAL TO PSOM
NOTE: Only wiring harness end of connector is to be probed.
* Connect Rotunda Digital Volt-Ohmmeter 014-00407 or equivalent to Pin 4 (speed in ) and Pin 5 (speed in -) of the PSOM connector (C252).
* Does the voltage increase smoothly and continuously from 0 to approximately 3.5 volts as vehicle (driveshaft) speed increases from 0 to 48 km/h (0 to 30 mph)?
OR:
* If available, a frequency counter may be connected to Pin 4 (Speed in ) and Pin 5 (Speed in -).
* Does the displayed frequency of the signal increase smoothly and continuously from 0 to approximately 667 Hz at approximately 48 km/h (30 mph)?
OR:
* If neither a voltmeter nor frequency counter is available, vehicle speed control may be used as a good indicator. If it works normally, then the speedometer module is at least receiving a speed input signal and the wiring and sensor can be assumed to be good.
A diagram from Steve83:
Substitute RABS for the mention of the 4WABS module in the diagram. Regardless of which brake control system the truck has the VSS signal flow to the PSOM is exactly the same.
Did you disconnect the wiring to the RABS module as mentioned earlier? A very common cause of the issue you describe.
Make all checks payable to CASH
rla2005,
Thank you for the response.
No I did not disconnect the RABS module because I'm not sure what it looks like. I understand that it is behind the glove box? Is this a box or plug or is it marked.
If disconnecting the RABS module makes the odometer work ? then does it need to be replaced?
I apologize if you feel it is leading someone astray.
If you were still wondering, it's a PSOM diagram for a '96 Bronco. '93-95 is similar.
