Front Sway Bar Problems Bolt Dont Fit
My 04' F-350 SRW 4x4 had bad sway bar end links and main bar bushings. Truck has 130K mi. I purchased new end links and bushings for the main bar and still have a terrible clunk under my feet when the tires hit something uneven. I took down the driver side this afternoon and the end link bushings are great but I did find that the bolt that goes through the bushing and the frame at the top of the endlink is very very loose in the metal bushing. I would say the bolt that is in the end link is 1 whole size to small for the metal bushing thats mounted to the frame. There is a good 1/8-1/16th play or more its def not correct. I cant read the part number off the driver side end link any more but the passenger side is the matching one and it its part number is 1C3Z-5K483-BA. I dont know if ford made different size bolts or if the metal bushing is just worn out. If its worn out is there a part# for that I cant see one on the part. I ordered the Moog endlinks the other day thinking that I had worn out the ford one again. They should be here this week and I will see if the bolt fills the hole better. Untill then I dont know what to do as I dont think the bolt comes out of the end link and even if it did I couldnt put a larger bolt in as it wouldnt go through the endlink bushing. Any help would be appreciated. Thanks
Ryan
Ryan
on
Ryan
Ryan
A larger bolt would help out alot for going through the bushing thats mounted to the frame but the larger bolt is not going to go through the bushing in the endlink. THe bolt in the end link is in there tight and im sure it could be pressed out but thats not the issue. Once you press out the bolt how are you going to get a larger one through the endlink to go through the frame?
on
Yeah I think we are confusing on another maybe. The bolt that came with my ford factory replacement endlink has the bolt at the top and its in there its not going to be comming out easily also yes the holder the piece of steel thats on the frame rail that the bolt goes though could take a bigger bolt and everything would be fine but that ford factory end link with the bolt in it is as big a bolt as you are going to get in it. I thought about a sleeve of sorts around it but its tight I mean you would have to have a metal sleeve thats got a thinkness of MAYBE 1/16th. I am going to call ford tomorrow and maybe there are different once for my year or something. I cant be the only one with this problem of the bolt being to small for the frame mounted bushing. Wrapping something around it MAY help but thats kinda ghetto. I want the correct piece. I could see ford giving me a hassel about this if it was an aftermarket part but its their end link. Now again I do have the moogs coming in a week or so. we will see what they are. If they arent right either I will just return them.
Buy some regular bolts, washers and nuts for replacements if need be. I use Gr8 (10.9) but Gr5 should suffice. If you need to drill out the bushings sleeve slightly for the larger bolts that is ok but you do not want to remove too much material.
I just bought some greaseable Moog end links for my dads truck from Rock Auto. They have a greaseable ball joint and stud built in so no bolts to deal with. They were not cheap but still cheaper than Motorcraft and since they are greaseable they should last a very long time. They are replacing energy suspension bushings because they make noise despite being lubed several times.
I wont be drilling it out as there has to be a reason its like this. I do have the greesable Moogs on the way as well I just hope that the bolt is the right size and fills the gap in the spacer on the frame. If not i'm gunna be really pissed. Im curious to hear what Ford has to say when I call this AM. Will post. Thanks again Ryan
on
Ok well I spoke with Ford and will call Moog next. Accordibg to Ford there is a piece that goes over the bolt to take up the space and it comes with the bolt. He told me what probably happend was when i took my old ones out since i reused the bolts i didnt put it back in. I am not sure i belive that but he sounded very confident. He says he has everything to rebuild in stock. So i will be heading over after work to take a look. I can always return rhe Moogs untill i need them if this is the problem. The bushings in these Ford facotry endlinks i have now are great only 4-5mo old so i might as well use them until they are gone. IF its as sime as he says of buying a new upper endlink bolt and using it with the sleeve. Will let you know.
on
Yeah thats basically what it comes down to now Ford claimed there i a special bolt so i will go take a look at what hes got. I will know by looking at it right away if its what I need. I tried to get in touch with moog but couldnt locate a phone number was only able to sed an email so I did. I wont hold my breath on a reply
Well after leaving ford and speaking with a tech there we have cone to the conclusion that the problem is the spacer piece on the frame. Thats the one that has the 2 bolts that bolt from the bottom up. The bolt is not supposed to have play in there as i suspected. Of course not in stock but will have them tomorrow. Will test on their counter woth both pieces the spacer piece and the bolt from the end link. 33$ for each spacer. Not to bad i guess.
on
