Bad radio or something else?
Have you checked to make sure all the wires (like the speaker wires) are connected? The messed up display wouldn't prevent sound from coming out but does make it hard to tune . If the connections check out, I'd bet the radio is bad. The radio just has a few wires going in (power, ground, antenna, memory) and most of the wires go out to the speakers.
Just to repeat what has been said, in your year truck, the standard factory radio has individual circuits for: speakers; radio memory; radio main power; and faceplate light.
The speakers circuits run from the radio to the speakers. They do not interact with any other system in the truck.
The radio memory is always hot. It keeps the memory for the programmed radio stations and powers the clock. It is fuse #8. Light green wire/yellow stripe.
The radio main power is switched from the key. It runs the radio itself. It is fuse #11, yellow wire/black stripe.
The faceplate light is an orange wire/black stripe. It comes from the light switch. The radio must be removed from the dash to replace the bulb.
!!!! The ground for the radio is RED !!!! Why Ford did this is a mystery to me!
If you replace the radio, Buy a small harness (~$5) from Radio Shack or Amazon that connects to the back of the new radio and will plug into the Ford main harness.. It will make your life MUCH easier in this new install, future upgrades, or troubleshooting. There is no need to hack up the factory harness.
Amazon.com: Metra 1985-2004 Ford Lincoln Mercury Non Premium Sound Wiring Harness: Car Electronics
dgoodsy
07-31-2019 10:23 AM
Locorotc
33
10-01-2010 07:50 PM
ford_racing_4_life
11-21-2007 08:54 PM
