Stock cam specs
Stock cam specs
Ok guys, I have a 4.9 on the engine stand and a cloyes timing set ready to go on. My question is what is the stock intake lobe centerline angle for me to shoot for on the degree wheel? Ive read alot about advancing the stock cam but cant find what that stock intake centerline angle is to determine if it is straight up, retarded or advanced. Im using the .050 on either side of max lift method added together and divided by two to get the centerline. I think i just need the stock specs including the intake centerline and work from there. Ill keep everyone posted on the results. Thanks.
I think so. The engine runs much smoother and idles at 22 inches of vacuum. It also isnt as fuel hungry as with the isky cam for the same power. It is nice to not hear that awful rattling sound coming from under the timing gear cover with the cheapo Advance auto timing gears. The Cloyes set is definately the way to go.
The big test will be in Feb. when it gets an emissions test here in the **** state of NJ.
Motorhead351
47
08-27-2008 05:34 AM
BaronVonAutomatc
03-20-2008 11:57 AM
DeGideo
07-17-2003 06:57 PM
Boss300
03-29-2002 03:03 PM
