Mustang gas tank
Old 10-16-2012, 07:24 PM
fordtruck60's Avatar
fordtruck60
fordtruck60 is offline
Mustang gas tank
What is the best year of Mustang tank to fit on the rear frame rails? 68? 69? Also, How did you mount it? Do any of these have return lines?
Just curious as I am still planning my build for this winter which is coming soon!
Thanks
Old 10-17-2012, 07:55 AM
THartman's Avatar
THartman
THartman is offline
INSTALLING A MID-60's Mustang Tank in a '53 F-100 truck
That answers the questions pretty well. I think 68 and earlier was 16 gallon, 69 was 20, and 70 was 22 gallon. All of them should fit fine.
Old 10-17-2012, 08:15 AM
Walston's Avatar
Walston
Walston is offline
Old 10-17-2012, 06:44 PM
fordtruck60
Thanks guys! The information and photo's were just what I needed! Looks like a real easy install after seeing these. I think I will go with the under frame with channels so it will be easier if removal is needed. The fun began today as my helper and I stripped all the sheetmetal, doors, and box off the truck. Then completely power washed everything. The cab was alot heavier than I expected so we will be removing that tomorrow with a proper lift. Man, the floor vents and cowl drains were solid full of mice nests and lots of good things! It took awile to clear all of that out completely. The good thing is they are not all rusted out. Well, It's a start.
Thanks Again
I will take photos of the process and post them soon.
Old 10-21-2012, 04:22 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1965/68: C5ZZ-9002-D 16 gallons / 1969: C9ZZ-9002-A 20 gallons / 1970 without Evaporative Emission: DOZZ-9002-A 22 gallons / 1971/73 without Evap/Em: D1ZZ-9002-A 20 gallons.
Old 05-07-2015, 05:31 AM
dirtyb's Avatar
dirtyb
dirtyb is offline
Originally Posted by Walston
Check out my gallery. I used a 1969.
1960 Ford F100 4x2 - Gas Tank Install
Walston,
How low below the bottom of the body does the tank hang? I want to lower my truck and want the bottom of the tank to be above the bottom of the box. Do you have pictures of that?
Thanks!
Old 05-08-2015, 08:03 AM
Walston's Avatar
Walston
Walston is offline
You can't really see it at stock height, but I don't have a great picture. I will try to get a better one in the coming days. Here is what I have. You can see the tank by looking by the license plate.
Old 05-08-2015, 12:08 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Walton; I always enjoy seeing your truck.
Old 05-11-2015, 06:24 AM
dirtyb's Avatar
dirtyb
dirtyb is offline
Thanks, I'm ordering a tank today!
61alleycat
1961 - 1963 F100 Unibody
04-01-2018 07:35 PM
tony1947
1947 and Older Ford Trucks
11-07-2014 08:51 AM
reed1951
03-31-2011 07:14 PM
My 1965 truck
02-20-2004 10:24 AM
marketer
03-25-2001 10:25 AM
Quick Reply: Mustang gas tank
