Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-12-2012, 01:26 PM
fast58's Avatar
fast58 fast58 is offline
Garage is empty, add now
fast58 is starting off with a positive reputation.
Kyle Brazier
2003 Police Int. Engine in 1958 f100
Hello all,
I have an idea bouncing around in my head.
Some of you may be aware that I did the 2003 Crown Victoria Police Interceptor front suspension swap, like several other Ford guys on this forum. The idea that I have been kicking around is how well would a 2003-whenever Police Car engine and transmission perform in my truck (1958 F-100 by the way)? I believe the actual size is 4.6 L with ~225 hp. The advantage of this swap would be fuel injection, programmable computer, and possible MPG improvement.
What I am wondering is if it would be worth the trouble of doing this swap. The setup I have now is a 1979 351 W bored .030 over with the modifications listed in my signature. Any and all comments/opinions are welcomed.
Thanks
__________________
http://www.ford-trucks.com/forums/im...ine=1324186537
1958 Ford F-100. 351 W .030 over and Speed Pro flat top pistons, Comp Cams 224/226, World Windsor Sr. heads, Edelbrock Performer intake, Holley 750 carb, Roller rocker arms, Proform one-wire distributor, MSD 6-AL ignition.
  #2 (permalink)
Old 10-12-2012, 04:17 PM
THartman THartman is offline
THartman is starting off with a positive reputation.
It depends on what you want. If you still have the original mounting points on your CV cross member that should make it easy - at least for that part. I have a 4.6 from a Mark VIII, the 4r70W, and IRS going in my truck along with the CV IFS and possibly the P71 driveshaft. It will be a few weeks before we start the engine part of the swap.
This article shows some pictures of the engine in a '56 1956 Ford F100 - 5.0L V8 DOHC Engine - Truckin' Magazine
  #3 (permalink)
Old 10-12-2012, 05:10 PM
fun-ford's Avatar
fun-ford fun-ford is offline
1960 Ford F-250
My Garage
fun-ford is starting off with a positive reputation.
kevin Ingle
I have a 2002 4.6 engine in my 54 f100
I bought a complete car and used the front suspension (2002)
engine, trans,radiator.
I have put about 6,000 miles on it this summer,no problems.
22-25 mpg,never gets above 190 degrees ,4 wheel disk
I used a detail zone wiring harness.
I am building a 60 Crew cab and plan on using a crown vic drive train in it also
Check my album for photos
  #4 (permalink)
Old 10-12-2012, 05:12 PM
Beechkid Beechkid is offline
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
With what you have listed on your 351, I think it would be a wash between the two....there is very litle different between a PI & regular 4.6.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #5 (permalink)
Old 10-13-2012, 10:04 AM
fast58's Avatar
Kyle Brazier
Would it even be worth the trouble though? I mean it's going to be more money and time to change over, but will it be worth it? But if I am going to go through the trouble of changing over to EFI, should I hunt up a Lightning supercharged motor instead?
__________________
  #6 (permalink)
Old 10-13-2012, 12:36 PM
Quote:
If you want to convert your existing to EFI & add a blower, do so with a forged crank etc....there are plenty of DIY EFI systems (stand alone) & in reality, you will 1) be $ ahead 2) have much less labor involved including troubleshooting/adapting 3) a crapload of power equal to or better than the 4.6 PI or Lightning and and 4) not having to worry about what hidden dangers lurk in the beat & abused Lightening engine you have just bought for $5k+
__________________
  #7 (permalink)
Old 10-17-2012, 12:03 AM
fast58's Avatar
Kyle Brazier
Quote:
I wasn't aware they were that expensive. I was thinking more along the lines of finding a cheap wrecked Lightning and buying the whole truck for a couple grand at the most. Then maybe putting $1000 in the engine. By the time I buy a supercharger for my engine it will be $5000, plus the forged pistons and crank $1000, the time of pulling the motor and rebuilding it, and all the headache that goes with it.
I do agree that the Lightning motor will be abused though, thus the plan to rebuild it.
__________________
  #8 (permalink)
Old 10-17-2012, 04:40 PM
Used lightning engines start off at $5k....if you could find a truck for $2k.....there would probably be not much for salvaging....unless you got real lucky.
__________________
  #9 (permalink)
Old 10-19-2012, 10:37 PM
fast58's Avatar
Kyle Brazier
Well that changes the plans a little... I wasn't aware they were so expensive. Maybe the 4.6 doesn't sound so bad after all.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
