5spd manual trans swap???
ZF 5 speed with an adapter. You need a ZF from behind a 300 six or 351w V8:
Ford FE Transmission Adapters
This will not be inexpensive.
Your other choices is to search heaven and earth for an OD Clark and futz around with that conversion, or go to the equally expensive NV4500 conversion:
High Impact - NV4500 5spd
Say you got a 20% improvement. You are now at 9.6 mpg. Do the math and see how long it will take to pay this off.....
Same problem with an auto. You need the adapter, up to $850 to put a GM 700R or Ford AOD behind an FE. Not sure about the 700R, but the AOD needs a little work to handle the FE and can be quite expensive if you buy one already beefed.
Given the OD ratios of .78 or so, figure MAYBE 20% MPG improvement in good conditions.
kevh481
07-05-2016 03:22 AM
bobbyray1963
02-02-2015 08:12 PM
MERCMX
08-19-2014 07:35 AM
papaul
02-04-2001 09:20 PM
