55 F100 Antenna Options?
Hey guys,
I have a basic radio in my truck but the antenna does not work well and I need a new one. I have already moved over to the dark side and don't want the 3 foot tall metal antenna anymore. I thought it would look slick to have a shorty 4-10" black antenna. I can find them, but I don't know the angle of the truck base that I would need.
Any of you replace your antenna with something similar that worked? The curve of the truck is killing alot of the "easy" options.
Thanks,
Tyson
Thanks,
Tyson
If your on the darkside maybe fill that hole and use one of these that I'm looking at.
http://midfifty.com/item.php?INV_ID=100
Mid Fifty F-100 Parts - Radio Antenna, Electronic, 9 Ft Cable
Received 5,160 Likes
on
In my opinion you will not be happy with that type of antenna [Mid-Fifty] unless you mount it to your windshield. The short black one you mentioned will come with an adjustible base that I think will fit your hole ok. There is no good option to good radio reception [am and fm] than a fender mounted one. You already have a hole, so I would use it.
spidk43
02-24-2006 03:49 PM
