Hesitation on startup 302
I bought a 1996 F150 302, 5 spd with 168K mi. I've done all of the usual new (used) truck stuff. Fluids, filters, flush, plugs, wires, cap, rotor, seafoamed, new belt, battery, thermostat...you name it. One problem I have is that on startup, it cranks right up but immediately stumbles off idle and will occasionally quit. It will start right back up. Also, it doesn't always quit. There are no codes and I have cleaned the throttle body and IAC. New PCV installed. I've put in all new Motorcraft clutch hydraulics, as well. Runs like a champ, only problem is the stumble on starting. Ideas?
mustangman65_79
37
01-22-2012 01:38 PM
BDSSUperDuty37
11-29-2010 08:42 PM
Dean88
37
06-10-2007 06:30 PM
caddywhompus
03-25-2004 07:36 AM
