1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99 Exhaust manifold replacement
Old 10-04-2012, 08:25 AM
Joe Bucky's Avatar
Joe Bucky
Joe Bucky is offline
I just bought a 99 250 Superduty ($5500) w/130k mi) 3 weeks ago that had been sitting for 2 years basically, and I expected it to run rough for a few tanks of gas. The shocks are shot, getting them replaced tomorrow morning, and the brake pads squeel like crazy. My question to you guys is the smell of exhaust coming up into the cab at an idle is pretty noticable, could it be time to change the exhaust manifolds? It seems pretty underpowered right now, and louder than should be. I cannot see a hole in the pipes or muffler, but I am only looking at it from the bottom.
Is it something a novice mech like me could handler on the weekend doing, or is it better left to a pro? Thanks
Old 10-04-2012, 10:00 AM
X1Lightning's Avatar
X1Lightning
X1Lightning is offline
odds are your manifolds are fine. there is probably a leak in one of the pipes, they will rot out a lot faster than the manifolds.
Just get under the truck and check the whole exhaust run
Old 10-04-2012, 10:43 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
If you hear any ticking sounds then the manifolds are prob the answer..Most northern trucks with that many miles could use new manifolds and gaskets and stainless studs..The manifolds rust ,warp and crack. I did mine at 80k or so.
Dick
Old 10-04-2012, 12:08 PM
dkf's Avatar
dkf
dkf is offline
The stainless exhaust manifold studs snap off. The M8 studs are too small to handle all that expansion and contraction. If the manifolds are not warped they can usually be salvaged.
Old 10-04-2012, 04:28 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
The stainless studs and nuts from ford are working fine on my 99.. I put two new manifolds on also. Maybe with old manifolds they break quicker. I don't know. There are stainless stud kits on ebay. I haven't tried them.
http://stores.ebay.com/METRIC-SCREW-...=p4634.c0.m322 I just bought the one's for the y pipe..
Dick
Old 10-04-2012, 06:42 PM
dkf's Avatar
dkf
dkf is offline
Both my dad and my truck came with stainless studs and those crappy powdered metal nuts. He had a couple that sheared off and needed replaced. I got rid of my stock logs at around 20k miles or so for headers and had one broke stud. These are on an 03' and a 04' 6.8l. The V10 manifolds are longer, heavier and all stainless. The longer manifold probably expands and contracts more than a 5.4l manifold.
xd2200
10-04-2018 10:49 AM
Glens67
12-10-2016 04:24 PM
RUSTANG67
Modular V10 (6.8l)
09-19-2007 07:28 AM
OhioRiverFordMan
Exhaust Systems
09-29-2002 01:42 AM
geoaigel
1997 - 2003 F150
09-28-2002 11:54 AM
Quick Reply: 99 Exhaust manifold replacement
