4X4 operation 101 for dummy
#32
#33
yea it converts the one handle shfter into 2. they both pivot on the same point as the old single handle but each pin on the t-case is controlled individually by each handle. this way u can run rear axle only high or low, front axle only high or low, or (front axle high w/ rear axle in low, or front axle low and rear axle high.) <----- i wouldnt suggest either of the last two unless your pretty much floating in the swamp. i like the idea of being able to put the rear axle in low and having the ability of putting the front in neutral.
#34
#35
#36
